由 小何 贡献,Ai-Thinker 进行整理
AI-WB2的easyflash文件系统,刷写程序、OTA后不掉数据哦 ​
移植easyflash和另一个spiffs文件系统刷写程序、OTA后不掉数据原理都差不多,这里再说一次
查看项目下的Make File
This is a project Makefile. It is assumed the directory this Makefile resides in is a ​
project subdirectory. ​
PROJECT_NAME := LivingRoomCock PROJECT_PATH := $(abspath .) PROJECT_BOARD := evb export PROJECT_PATH PROJECT_BOARD #CONFIG_TOOLPREFIX :=
-include ./proj_config.mk
ifeq ($(origin BL60X_SDK_PATH), undefined) BL60X_SDK_PATH_GUESS ?= $(shell pwd) BL60X_SDK_PATH ?= (BL60XSDKPATHGUESS)/../../../..(info ****** Please SET BL60X_SDK_PATH ******) (info∗∗∗∗∗∗TryingSDKPATH[(BL60X_SDK_PATH)]) endif
COMPONENTS_NETWORK := sntp dns_server COMPONENTS_BLSYS   := bltime blfdt blmtd blota bloop loopadc looprt loopset COMPONENTS_VFS     := romfs cjson
INCLUDE_COMPONENTS += freertos_riscv_ram bl602 bl602_std newlibc wifi wifi_manager wpa_supplicant bl602_os_adapter wifi_hosal hosal mbedtls_lts lwip lwip_dhcpd vfs yloop utils cli aws-iot httpc httpd dns_server netutils blog blog_testc INCLUDE_COMPONENTS += easyflash4 coredump lwip_altcp_tls_mbedtls  blcrypto_suite bl_os_adapter rfparam_adapter_tmp spiffs
INCLUDE_COMPONENTS += $(COMPONENTS_NETWORK) INCLUDE_COMPONENTS += $(COMPONENTS_BLSYS) INCLUDE_COMPONENTS += $(COMPONENTS_VFS) INCLUDE_COMPONENTS += $(PROJECT_NAME)
include $(BL60X_SDK_PATH)/make_scripts_riscv/project.mk
最终调用make_scripts_riscv/project.mk
flash-only:         cd (BL60X_SDK_PATH)/tools/flash_tool && env SDK_APP_BIN=(APP_BIN) SDK_BOARD=(PROJECTBOARD)SDKNAME=(PROJECT_NAME) SDK_MEDIA_BIN=(APPMEDIABIN)SDKROMFSDIR=(APP_ROMFS_DIR) SDK_DTS=(PROJECTDTS)SDKXTAL=(PROJECT_BOARD_XTAL) BL_FLASH_TOOL_INPUT_PATH_cfg2_bin_input=$(APP_BIN) (FLASHTOOLTYPE)−−chipname=BL602−−baudrate=(SERIAL_BAUDRATE) --port=(SERIALPORT)−−pt=(BL60X_SDK_PATH)/tools/flash_tool/chips/bl602/partition/partition_cfg_4M.toml --dts=(BL60XSDKPATH)/tools/flashtool/chips/bl602/devicetree/04−blfactoryparamsIoTKitA40M−20220625.dts−−boot2=(BL60X_SDK_PATH)/tools/flash_tool/chips/bl602/builtin_imgs/boot2_isp_bl602_v6.5.1/boot2_iap_release.bin --firmware=$(APP_BIN)
最终得出Flash分区文是/tools/flash_tool/chips/bl602/partition/partition_cfg_4M.toml。 备份文件partition_cfg_4M.toml文件
增加easyflash文件系统分区
[pt_table] #partition table is 4K in size address0 = 0xE000 address1 = 0xF000
[[pt_entry]]
type = 0
name = "FW"
device = 0
address0 = 0x10000
size0 = 0x100000
address1 = 0x110000
size1 = 0x100000
compressed image must set len,normal image can left it to 0 ​
len = 0
[[pt_entry]]
type = 0
name = "spiffs"
device = 0
address0 = 0x210000
size0 = 0x28000
address1 = 0x238000
size1 = 0x8000
len = 0
[[pt_entry]]
type = 2
name = "mfg"
device = 0
address0 = 0x240000
size0 = 0x32000
address1 = 0
size1 = 0
len = 0
[[pt_entry]]
type = 3
name = "media"
device = 0
address0 = 0x272000
size0 = 0x1000
address1 = 0
size1 = 0
len = 0
[[pt_entry]]
type = 4
name = "PSM"
device = 0
address0 = 0x273000
size0 = 0x33000
address1 = 0
size1 = 0
len = 0
[[pt_entry]]
type = 5
name = "KEY"
device = 0
address0 = 0x2A6000
size0 = 0x2000
address1 = 0
size1 = 0
len = 0
[[pt_entry]]
type = 6
name = "DATA"
device = 0
address0 = 0x2A8000
size0 = 0x5000
address1 = 0
size1 = 0
len = 0
[[pt_entry]]
type = 7
name = "factory"
device = 0
address0 = 0x2AD000
size0 = 0x7000
address1 = 0
size1 = 0
len = 0
#if user want to put RF calibration data on flash, uncomment following pt entry #[[pt_entry]] #type = 8 #name = "rf_para" #device = 0 #address0 = 0x1FF000 #size0 = 0x1000 #address1 = 0 #size1 = 0
#len = 0
[[pt_entry]]
type = 0
name = "spiffs"
device = 0
address0 = 0x210000  ##给spiffs文件系统用,开始地址
size0 = 0x28000         ##给spiffs文件系统用,大小
address1 = 0x238000  ##给easyflash文件系统用,开始地址
size1 = 0x8000           ##给easyflash文件系统用,大小
len = 0
修改安信可已移植好的ef_port.c
  • This file is part of the EasyFlash Library.
  • Copyright (c) 2015, Armink, <armink.ztl@gmail.com>
  • Permission is hereby granted, free of charge, to any person obtaining
  • a copy of this software and associated documentation files (the
  • 'Software'), to deal in the Software without restriction, including
  • without limitation the rights to use, copy, modify, merge, publish,
  • distribute, sublicense, and/or sell copies of the Software, and to
  • permit persons to whom the Software is furnished to do so, subject to
  • the following conditions:
  • The above copyright notice and this permission notice shall be
  • included in all copies or substantial portions of the Software.
  • THE SOFTWARE IS PROVIDED 'AS IS', WITHOUT WARRANTY OF ANY KIND,
  • EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
  • MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
  • IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY
  • CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT,
  • TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
  • SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
  • Function: Portable interface for each platform.
  • Created on: 2015-01-16 */
#include <easyflash.h> #include <stdarg.h> #include <stdio.h> #include <string.h> #include <FreeRTOS.h> #include <semphr.h> #include <bl_mtd.h> #include <ef_cfg.h> #include <hosal_flash.h> #include <hal_boot2.h>
uint32_t ENV_AREA_SIZE; uint32_t SECTOR_NUM; uint32_t EF_START_ADDR;
/* default environment variables set for user */ static const ef_env default_env_set[] = {         {"boot_times", "3", 1} };
static SemaphoreHandle_t env_cache_lock = NULL;
  • Flash port for hardware initialize.
  • @param default_env default ENV set for user
  • @param default_env_size default ENV size
  • @return result */ EfErrCode ef_port_init(ef_env const **default_env, size_t *default_env_size) {     uint32_t addr0, addr1;     uint32_t size0, size1;     int active, ret;
ret = hal_boot2_partition_addr("spiffs",&addr0,&addr1,&size0,&size1,&active);
if (size1 < 8 * 1024) {         //printf("[ERROR]psm partition is less than 8k,easyflash can not work!");         return EF_ENV_INIT_FAILED;     }     else{         EF_START_ADDR = addr1;         ENV_AREA_SIZE = (size1 / EF_ERASE_MIN_SIZE) * EF_ERASE_MIN_SIZE;         SECTOR_NUM = ENV_AREA_SIZE / EF_ERASE_MIN_SIZE;         //printf("ENV AREA SIZE %ld, SECTOR NUM %ld\r\n", ENV_AREA_SIZE, SECTOR_NUM);
*default_env = default_env_set;         *default_env_size = sizeof(default_env_set) / sizeof(default_env_set[0]);
//printf("*default_env_size = 0x%08x\r\n", *default_env_size);
#if configUSE_RECURSIVE_MUTEXES         env_cache_lock = xSemaphoreCreateRecursiveMutex();     #else         env_cache_lock = xSemaphoreCreateMutex();     #endif                  return EF_NO_ERR;     } }
  • Read data from flash.
  • @note This operation's units is word.
  • @param addr flash address
  • @param buf buffer to store read data
  • @param size read bytes size
  • @return result */ EfErrCode ef_port_read(uint32_t addr, uint32_t *buf, size_t size) {     EfErrCode result = EF_NO_ERR;
if(hosal_flash_raw_read((uint32_t*)buf, addr, size) != 0){                  //printf("--------EF_READ_ERR--------");         result = EF_READ_ERR;     }     //printf("--------ef_port_read--------%ld;%lx;%d",*buf,addr,size);     return result; }
  • Erase data on flash.
  • @note This operation is irreversible.
  • @note This operation's units is different which on many chips.
  • @param size erase bytes size
  • @return result */ EfErrCode ef_port_erase(uint32_t addr, size_t size) {     EfErrCode result = EF_NO_ERR;
/* make sure the start address is a multiple of EF_ERASE_MIN_SIZE */     EF_ASSERT(addr % EF_ERASE_MIN_SIZE == 0);
if(hosal_flash_raw_erase(addr, size) != 0){         //printf("--------EF_ERASE_ERR--------");         result = EF_ERASE_ERR;     }     //printf("--------ef_port_erase--------%lx;%d",addr,size);     return result; } /**
  • Write data to flash.
  • @note This operation must after erase. @see flash_erase.
  • @param buf the write data buffer
  • @param size write bytes size
  • @return result */ EfErrCode ef_port_write(uint32_t addr, const uint32_t buf, size_t size) {     EfErrCode result = EF_NO_ERR;         if(hosal_flash_raw_write((const uint32_t)buf, addr, size) != 0){                  //printf("--------EF_WRITE_ERR--------");         result = EF_WRITE_ERR;     }
//printf("--------ef_port_write--------%ld;%lx;%d",*buf,addr,size);     return result; }
  • lock the ENV ram cache / void ef_port_env_lock(void) {     #if configUSE_RECURSIVE_MUTEXES     xSemaphoreTakeRecursive(env_cache_lock,                  portMAX_DELAY); #else     / You can add your code under here. */     xSemaphoreTake( env_cache_lock,                  portMAX_DELAY ); #endif
  • unlock the ENV ram cache / void ef_port_env_unlock(void) {     #if configUSE_RECURSIVE_MUTEXES     xSemaphoreGiveRecursive(env_cache_lock); #else     / You can add your code under here. */     xSemaphoreGive( env_cache_lock ); #endif }
extern void vprint(const char fmt, va_list argp); /*
  • This function is print flash debug info.
  • @param file the file which has call this function
  • @param line the line number which has call this function
  • @param format output format
  • @param ... args
*/ void ef_log_debug(const char *file, const long line, const char *format, ...) {
#ifdef PRINT_DEBUG
va_list args;
/* args point to the first variable parameter */     va_start(args, format);
/* You can add your code under here. */     vprint(format, args);
va_end(args);
#endif
  • This function is print flash routine info.
  • @param ... args */ void ef_log_info(const char *format, ...) {     va_list args;
/* You can add your code under here. /     vprint(format, args);         va_end(args); } /*
  • This function is print flash non-package info.
  • @param ... args */ void ef_print(const char *format, ...) { va_list args;
va_end(args);
hal_boot2_partition_addr("spiffs",&addr0,&addr1,&size0,&size1,&active);这个函数可以得到分区文件partition_cfg_4M.toml的开始地址和大小。修改spiffs的起始地址和大小,cfg.phys_addr = addr0;cfg.phys_size = size0;spiffs文件系统就存在flash这个空间,烧写程序和OAT升级都不会破坏这个空间,也就是spiffs数据不会丢失。
else{
这个给easyflash使用。烧写程序和OAT升级都不会破坏这个空间,也就是easyflash 数据不会丢失。
上传的附件:
(580.25 KB, 下载次数: 8)
