由 小何 贡献,Ai-Thinker 进行整理
AI-WB2的 OTA 升级教程 ​
根据博流的demo_ota 项目为例,复制博流的原厂 SDK 的customer_app/system/ota/demo_ota 到WB2 模组 SDK 的application 目录下,
  • demo_ota/proj_config.mk 中新增:CONFIG_LINK_ROM=1
    #compiler flag config domain
    #CONFIG_TOOLPREFIX := #CONFIG_OPTIMIZATION_LEVEL_RELEASE := 1 #CONFIG_M4_SOFTFP := 1
    #board config domain
    CONFIG_BOARD_FLASH_SIZE := 4
    #firmware config domain
    #set CONFIG_ENABLE_ACP to 1 to enable ACP, set to 0 or comment this line to disable #CONFIG_ENABLE_ACP:=1 CONFIG_BL_IOT_FW_AP:=1 CONFIG_BL_IOT_FW_AMPDU:=0 CONFIG_BL_IOT_FW_AMSDU:=0 CONFIG_BL_IOT_FW_P2P:=0 CONFIG_ENABLE_PSM_RAM:=1 #CONFIG_ENABLE_CAMERA:=1 #CONFIG_ENABLE_BLSYNC:=1 #CONFIG_ENABLE_VFS_SPI:=1 CONFIG_ENABLE_VFS_ROMFS:=1 CONFIG_EASYFLASH_ENABLE:=1        #0 -> 1 CONFIG_SYS_APP_TASK_STACK_SIZE:=4096        #+ CONFIG_SYS_APP_TASK_PRIORITY:=15        #+
    CONFIG_FREERTOS_TICKLESS_MODE:=0        #1 -> 0
    #CONFIG_SYS_APP_TASK_STACK_SIZE:=4096        #- #CONFIG_SYS_APP_TASK_PRIORITY:=15        #-
    CONFIG_SYS_VFS_ENABLE:=1 CONFIG_SYS_VFS_UART_ENABLE:=1 CONFIG_SYS_AOS_CLI_ENABLE:=1 CONFIG_SYS_AOS_LOOP_ENABLE:=1 CONFIG_SYS_BLOG_ENABLE:=1 CONFIG_SYS_DMA_ENABLE:=0        #1 -> 0 CONFIG_SYS_USER_VFS_ROMFS_ENABLE:=0        #1 -> 0
    CONFIG_BT:=0
    CONFIG_BT_CENTRAL:=1        #+ CONFIG_BT_OBSERVER:=1        #+ CONFIG_BT_PERIPHERAL:=1        #+ CONFIG_BT_STACK_CLI:=1        #+ CONFIG_BT_MESH := 0        #+ ifeq ($(CONFIG_BT_MESH),1)        #+ CONFIG_BT_MESH_PB_ADV := 1        #+ CONFIG_BT_MESH_PB_GATT := 1        #+ CONFIG_BT_MESH_FRIEND := 1        #+ CONFIG_BT_MESH_LOW_POWER := 1        #+ CONFIG_BT_MESH_PROXY := 1        #+ CONFIG_BT_MESH_GATT_PROXY := 1        #+ endif
    CONF_ENABLE_COREDUMP:=1        #+
    #CONFIG_USE_XTAL32K:=0        #- #CONFIG_ENABLE_STACK_OVERFLOW_CHECK:=0        #-
    #blog enable components format :=blog_testc cli vfs helper LOG_ENABLED_COMPONENTS:=blog_testc hosal loopset looprt bloop blestack LivingRoomCock http_client_tcp ifeq ($(CONFIG_BT_MESH_SYNC),1) LOG_ENABLED_COMPONENTS += blsync_ble endif
    CONFIG_BL602_USE_ROM_DRIVER:=1 #CONFIG_BT_STACK_PTS:=0        #-
    CONFIG_LINK_ROM=1        #+
[color=rgba(0, 0, 0, 0.75)]其实在文件里已有genromap  [color=rgba(0, 0, 0, 0.75)]CONFIG_LINK_ROM=1,不需要demo_ota/proj_config.mk都要以,增加方法直接make
#!/bin/sh make CONFIG_CHIP_NAME=BL602 CONFIG_LINK_ROM=1 -j make flash-build exit $?
demo_ota.bin及生成 OTA 固件****make或./genromap就行成demo_ota.bin及生成 OTA 固件。 查看项目下的Make File
This is a project Makefile. It is assumed the directory this Makefile resides in is a ​
project subdirectory. ​
PROJECT_NAME := LivingRoomCock PROJECT_PATH := $(abspath .) PROJECT_BOARD := evb export PROJECT_PATH PROJECT_BOARD #CONFIG_TOOLPREFIX :=
-include ./proj_config.mk
ifeq ($(origin BL60X_SDK_PATH), undefined) BL60X_SDK_PATH_GUESS ?= $(shell pwd) BL60X_SDK_PATH ?= (BL60XSDKPATHGUESS)/../../../..(info ****** Please SET BL60X_SDK_PATH ******) (info∗∗∗∗∗∗TryingSDKPATH[(BL60X_SDK_PATH)]) endif
COMPONENTS_NETWORK := sntp dns_server COMPONENTS_BLSYS   := bltime blfdt blmtd blota bloop loopadc looprt loopset COMPONENTS_VFS     := romfs cjson
INCLUDE_COMPONENTS += freertos_riscv_ram bl602 bl602_std newlibc wifi wifi_manager wpa_supplicant bl602_os_adapter wifi_hosal hosal mbedtls_lts lwip lwip_dhcpd vfs yloop utils cli aws-iot httpc httpd dns_server netutils blog blog_testc INCLUDE_COMPONENTS += easyflash4 coredump lwip_altcp_tls_mbedtls  blcrypto_suite bl_os_adapter rfparam_adapter_tmp spiffs
INCLUDE_COMPONENTS += $(COMPONENTS_NETWORK) INCLUDE_COMPONENTS += $(COMPONENTS_BLSYS) INCLUDE_COMPONENTS += $(COMPONENTS_VFS) INCLUDE_COMPONENTS += $(PROJECT_NAME)
include $(BL60X_SDK_PATH)/make_scripts_riscv/project.mk
最终调用make_scripts_riscv/project.mk
Main Project Makefile ​
This Makefile is included directly from the user project Makefile in order to call the bouffalo.mk ​
makefiles of all components (in a separate make process) to build all the libraries, then links them ​
together into the final file. If so, PWD is the project dir (we assume). ​
This makefile requires the environment variable BL60X_SDK_PATH to be set to the top-level bl60x_sdk directory ​
where this file is located. ​
.PHONY: all build clean all_binaries list-components
MAKECMDGOALS ?= all all: all_binaries
FLASH_TOOL_TYPE:= ./bflb_iot_tool-ubuntu
see below for recipe of 'all' target ​
# other components will add dependencies to 'all_binaries'. The ​
reason all_binaries is used instead of 'all' is so that the flash ​
target can build everything without triggering the per-component "to ​
flash..." output targets.) ​
help:         @echo "Welcome to Ai-WB2 SDK build system. make targets:"         @echo ""         @echo "\033[33m"make all"\033[0m - Build app, components"         @echo "\033[33m"make clean"\033[0m - Remove all app components output"         @echo "\033[33m"make flash"\033[0m - Build and download firmware "         @echo "\033[33m"make flash-only"\033[0m - Only download firmware"         @echo "\033[33m"make eflash"\033[0m - Use the flash after erasing it"         @echo "\033[33m"make erase_flash"\033[0m - Erase all internal contents of flash"         @echo "\033[33m"make list-components"\033[0m - List all components in the project"         @echo "\033[33m"make [component name]"\033[0m - build a component as a library"
Non-interactive targets. Mostly, those for which you do not need to build a binary ​
NON_INTERACTIVE_TARGET += defconfig clean% %clean help list-components print_flash_cmd ​
dependency checks ​
ifndef MAKE_RESTARTS ifeq ("(filter4.(MAKE_VERSION))","") $(warning bl60x_sdk build system only supports GNU Make versions 3.81 or newer. You may see unexpected results with other Makes.) endif
endif  # MAKE_RESTARTS
can't run 'clean' along with any non-clean targets ​
ifneq ("(filterclean(MAKECMDGOALS))" ,"") ifneq ("(filter−outclean(MAKECMDGOALS))", "") $(error bl60x_sdk build system doesn't support running 'clean' targets along with any others. Run 'make clean' and then run other targets separately.) endif
OS ?=
make BL60X_SDK_PATH a "real" absolute path ​
* works around the case where a shell character is embedded in the environment variable value. ​
* changes Windows-style C:/blah/ paths to MSYS style /c/blah ​
ifeq ("$(OS)","Windows_NT")
On Windows MSYS2, make wildcard function returns empty string for paths of form /xyz ​
where /xyz is a directory inside the MSYS root - so we don't use it. ​
SANITISED_BL60X_SDK_PATH:=$(realpath (BL60XSDKPATH))FLASHTOOLTYPE:=./bflbiottool.exeelseSANITISEDBL60XSDKPATH:=(realpath $(wildcard $(BL60X_SDK_PATH))) endif
export BL60X_SDK_PATH := $(SANITISED_BL60X_SDK_PATH)
ifndef BL60X_SDK_PATH $(error BL60X_SDK_PATH variable is not set to a valid directory.) endif
ifneq ("(BL60XSDKPATH)","(SANITISED_BL60X_SDK_PATH)") $(error If BL60X_SDK_PATH is overriden on command line, it must be an absolute path with no embedded shell special characters) endif
ifneq ("(BL60XSDKPATH)","(subst :,,(BL60XSDKPATH))")(error BL60X_SDK_PATH cannot contain colons. If overriding BL60X_SDK_PATH on Windows, use MSYS Unix-style /c/dir instead of C:/dir) endif
disable built-in make rules, makes debugging saner ​
MAKEFLAGS_OLD := $(MAKEFLAGS) MAKEFLAGS +=-rR
Default path to the project: we assume the Makefile including this file ​
is in the project directory ​
ifndef PROJECT_PATH PROJECT_PATH := $(abspath $(dir $(firstword $(MAKEFILE_LIST)))) export PROJECT_PATH endif
A list of the "common" makefiles, to use as a target dependency ​
COMMON_MAKEFILES := $(abspath $(BL60X_SDK_PATH)/make_scripts_riscv/project.mk $(BL60X_SDK_PATH)/make_scripts_riscv/common.mk $(BL60X_SDK_PATH)/make_scripts_riscv/component_wrapper.mk $(firstword $(MAKEFILE_LIST))) export COMMON_MAKEFILES
The directory where we put all objects/libraries/binaries. The project Makefile can ​
configure this if needed. ​
ifndef BUILD_DIR_BASE BUILD_DIR_BASE := $(PROJECT_PATH)/build_out endif export BUILD_DIR_BASE
Component directories. These directories are searched for components (either the directory is a component, ​
or the directory contains subdirectories which are components.) ​
The project Makefile can override these component dirs, or add extras via EXTRA_COMPONENT_DIRS ​
ifndef COMPONENT_DIRS EXTRA_COMPONENT_DIRS ?= COMPONENT_DIRS := $(PROJECT_PATH)/components $(EXTRA_COMPONENT_DIRS) $(BL60X_SDK_PATH)/components $(BL60X_SDK_PATH)/customer_components (PROJECTPATH)/(PROJECT_NAME) $(PROJECT_COMPONENT) endif export COMPONENT_DIRS
The project Makefile can define a list of components, but if it does not do this we just take all available components ​
in the component dirs. A component is COMPONENT_DIRS directory, or immediate subdirectory, ​
which contains a bouffalo.mk file. ​
Use the "make list-components" target to debug this step. ​
#ifndef COMPONENTS
Find all component names. The component names are the same as the ​
directories they're in, so /bla/components/mycomponent/bouffalo.mk -> mycomponent. ​
using by [https://stackoverflow.com/questi ... ry-tree-for-c-files](https://stackoverflow.com/questions/3774568/makefile-issue-smart-way-to-scan-directory-tree-for-c-files) ​
ifeq ("$(wildcard ${BL60X_SDK_PATH}/components.mk)","") rwildcard = $(wildcard $1$2) (foreachd,(wildcard 1∗),(call rwildcard,$d/,2))COMPONENTSRALPATH:=(dir (foreachcd,(COMPONENT_DIRS),
                                                (callrwildcard,(cd)/,bouffalo.mk)
                                )) COMPONENTS := $(sort (foreachcomp,(COMPONENTS_RAL_PATH),$(lastword (subst/,,(comp))))) COMPONENTS_REAL_PATH := (patsubst(COMPONENTS_RAL_PATH)) else COMPONENTS := $(notdir $(PROJECT_PATH)) COMPONENTS_REAL_PATH := (PROJECTPATH)/(notdir $(PROJECT_PATH)) include (BL60XSDKPATH)/components.mk(info use existing components.mk file) endif #endif
After a full manifest of component names is determined, subtract the ones explicitly omitted by the project Makefile. ​
ifdef INCLUDE_COMPONENTS
match exclude comps with EXCLUDE_COMPONENTS variable ​
define include_comps_add include_path += (filter(1), (COMPONENTSREALPATH))endef(foreach comp,(INCLUDECOMPONENTS),(eval (callincludecompsadd,(comp)))) INCLUDE_COMPONENTS_REAL_PATH := $(include_path)
include components ​
COMPONENTS := $(filter $(INCLUDE_COMPONENTS), $(COMPONENTS)) COMPONENTS_REAL_PATH := $(filter $(INCLUDE_COMPONENTS_REAL_PATH), $(COMPONENTS_REAL_PATH)) endif export COMPONENTS
Resolve all of COMPONENTS into absolute paths in COMPONENT_PATHS. ​
If a component name exists in multiple COMPONENT_DIRS, we take the first match. ​
NOTE: These paths must be generated WITHOUT a trailing / so we ​
can use $(notdir x) to get the component name. ​
TODO remove multiple name in components ​
#COMPONENT_PATHS := (foreachcomp,(COMPONENTS),$(firstword (foreachcd,(COMPONENT_DIRS),$(wildcard $(dir (cd))(comp) (cd)/(comp))))) #COMPONENT_PATHS := (patsubst(COMPONENTS_RAL_PATH)) COMPONENT_PATHS := $(COMPONENTS_REAL_PATH) export COMPONENT_PATHS
Initialise project-wide variables which can be added to by ​
each component. ​
These variables are built up via the component_project_vars.mk ​
generated makefiles (one per component). ​
See docs/build-system.rst for more details. ​
COMPONENT_INCLUDES := COMPONENT_LDFLAGS := COMPONENT_SUBMODULES := COMPONENT_LIBRARIES :=
COMPONENT_PROJECT_VARS is the list of component_project_vars.mk generated makefiles ​
for each component. ​
Including $(COMPONENT_PROJECT_VARS) builds the COMPONENT_INCLUDES, ​
COMPONENT_LDFLAGS variables and also targets for any inter-component ​
dependencies. ​
See the component_project_vars.mk target in component_wrapper.mk ​
COMPONENT_PROJECT_VARS := (addsuffix/componentprojectvars.mk,(notdir $(COMPONENT_PATHS) )) COMPONENT_PROJECT_VARS := $(sort $(COMPONENT_PROJECT_VARS)) COMPONENT_PROJECT_VARS := $(addprefix (BUILDDIRBASE)/,(COMPONENT_PROJECT_VARS))
this line is -include instead of include to prevent a spurious error message on make 3.81 ​
-include $(COMPONENT_PROJECT_VARS)
Also add top-level project include path, for top-level includes ​
COMPONENT_INCLUDES += $(abspath $(BUILD_DIR_BASE)/include/) ​
export COMPONENT_INCLUDES
Set variables common to both project & component ​
include $(BL60X_SDK_PATH)/make_scripts_riscv/common.mk include $(BL60X_SDK_PATH)/make_scripts_riscv/toolchain.mk
all: ifeq ("(OS)","WindowsNT")elseifeq("(CONFIG_CHIP_NAME)", "BL602") endif         @echo "Building Finish. To flash build output. run 'make flash' or:"         @echo "c $(OS) ..."         @echo "cd (BL60X_SDK_PATH)/tools/flash_tool && env SDK_APP_BIN=(APP_BIN) SDK_BOARD=(PROJECTBOARD)SDKNAME=(PROJECT_NAME) SDK_MEDIA_BIN=(APPMEDIABIN)SDKROMFSDIR=(APP_ROMFS_DIR) SDK_DTS=(PROJECTDTS)SDKXTAL=(PROJECT_BOARD_XTAL) BL_FLASH_TOOL_INPUT_PATH_cfg2_bin_input=$(APP_BIN) (FLASHTOOLTYPE)−−chipname=BL602−−baudrate=921600−−port=/dev/ttyUSB0−−pt=(PROJECT_PATH)/img_conf/partition_cfg_4M.toml --dts=(PROJECTPATH)/imgconf/blfactoryparamsIoTKitA40M.dts−−firmware=(APP_BIN)"
bins: all         @cd $(BL60X_SDK_PATH)/image_conf; python3 flash_build.py $(PROJECT_NAME) $(CONFIG_CHIP_NAME) info: all         @cd (BL60XSDKPATH)/imageconf;envSDKAPPBIN=(APP_BIN) SDK_APP_MAP=$(APP_MAP) python3 codesize.py
If we have version.mk then prefer that for extracting BL60x_SP_SDK version ​
ifeq ("$(wildcard ${BL60X_SDK_PATH}/version.mk)","") BL_SDK_VER := $(shell cd {BL60X_SDK_PATH} && git describe --always --tags --dirty) EXTRA_CPPFLAGS ?= EXTRA_CPPFLAGS += -D BL_SDK_VER=\"(BL_SDK_VER)" $(info use git describe to generate Version Define) else include (BL60XSDKPATH)/version.mkifeq("(CONFIG_CHIP_NAME)", "BL602") $(info Your configuration chipname is Ai-Thinker Ai-WB2 Wi-Fi&BLE Module) endif BL_CHIP_NAME := $
Set default LDFLAGS ​
-nostdlib ​
--specs=nosys.specs ​
EXTRA_LDFLAGS ?= -Wl,--cref -nostartfiles
ifeq ("(CONFIGCHIPNAME)","VIRTEX7")LDFLAGS?= −march=rv32imc−mabi=ilp32 −g3−nostartfiles−Wl,−−noinhibit−exec,−−gc−sections,−−relax−Wl,−−cref −Wl,−−start−group (COMPONENT_LDFLAGS)
        -Wl,--end-group \
else E21_CPU_LDFLAGS := -march=rv32imfc
                   -mabi=ilp32f
LDFLAGS ?=  (E21CPULDFLAGS) (EXTRA_LDFLAGS)
        -Wl,--gc-sections
        -Wl,-static
        -Wl,--start-group
        $(COMPONENT_LDFLAGS)
        -Wl,--end-group
        -Wl,-EL
        -lm endif
Set default CPPFLAGS, CFLAGS, CXXFLAGS ​
These are exported so that components can use them when compiling. ​
If you need your component to add CFLAGS/etc for it's own source compilation only, set CFLAGS += in your component's Makefile. ​
If you need your component to add CFLAGS/etc globally for all source ​
#  files, set CFLAGS += in your component's Makefile.projbuild
If you need to set CFLAGS/CPPFLAGS/CXXFLAGS at project level, set them in application Makefile ​
#  before including project.mk. Default flags will be added before the ones provided in application Makefile.
CPPFLAGS used by C preprocessor ​
If any flags are defined in application Makefile, add them at the end. ​
CPPFLAGS ?=
Enable GNU extensions ​
CPPFLAGS += -D _GNU_SOURCE ifeq ((CONFIGENABLEACP),1)CPPFLAGS+=−DCONFUSERENABLEACPendififeq((CONFIG_ENABLE_CAMERA),1) CPPFLAGS += -DCONF_USER_ENABLE_CAMERA endif ifeq ((CONFIGENABLEPSMRAM),1)CPPFLAGS+=−DCONFUSERENABLEPSRAMendifEXTRACPPFLAGS?=CPPFLAGS+=−DBLCHIPNAME=\"(BL_CHIP_NAME)" -MMD -MP $(EXTRA_CPPFLAGS) CPPFLAGS += -DARCH_RISCV
Warnings-related flags relevant both for C and C++ ​
COMMON_WARNING_FLAGS = -Wall -Werror=all
        -Wno-error=unused-function
        -Wno-error=unused-but-set-variable
        -Wno-error=unused-variable
        -Wno-error=deprecated-declarations
        -Wextra
        -Wno-unused-parameter -Wno-sign-compare
ifdef CONFIG_WARN_WRITE_STRINGS COMMON_WARNING_FLAGS += -Wwrite-strings endif #CONFIG_WARN_WRITE_STRINGS
ifdef CONFIG_ENABLE_PSM_RAM COMMON_WARNING_FLAGS += -DCONF_USER_ENABLE_PSRAM endif
Flags which control code generation and dependency generation, both for C and C++ ​
-nostdlib ​
-fno-common ​
-funwind-tables ​
COMMON_FLAGS =
        -ffunction-sections -fdata-sections
        -fstrict-volatile-bitfields
        -fcommon \
Add -fshort-enums temporarily for bl702 ​
ifeq ("$(CONFIG_CHIP_NAME)", "BL702") COMMON_FLAGS += -fshort-enums endif
COMMON_FLAGS_M4_EXT :=
        -ffreestanding
        -fno-strict-aliasing
COMMON_FLAGS += $(COMMON_FLAGS_M4_EXT)
ifdef CONFIG_STACK_CHECK_NORM COMMON_FLAGS += -fstack-protector endif ifdef CONFIG_STACK_CHECK_STRONG COMMON_FLAGS += -fstack-protector-strong endif ifdef CONFIG_STACK_CHECK_ALL COMMON_FLAGS += -fstack-protector-all endif ifeq ((CONFIGENABLEFP),1)COMMONFLAGS+=−fno−omit−frame−pointer−DCONFENABLEFRAMEPTRendififeq((CONF_ENABLE_FUNC_BACKTRACE),1) PROJ_ELF:=(PROJECTNAME).elfCOMMONFLAGS+=−fno−omit−frame−pointer−DCONFENABLEFUNCBACKTRACEELF=(PROJ_ELF) -DCONF_BUILD_PATH=(BUILDDIRBASE)/(PROJ_ELF) endif
ifeq ($(CONFIG_ENABLE_STACK_OVERFLOW_CHECK),1) COMMON_FLAGS += -finstrument-functions -DCONF_ENABLE_STACK_OVERFLOW_CHECK endif
ifeq ("$(CONFIG_CHIP_NAME)", "VIRTEX7") OPTIMIZATION_FLAGS = -O2 else ifdef CONFIG_OPTIMIZATION_LEVEL_RELEASE OPTIMIZATION_FLAGS = -Os else OPTIMIZATION_FLAGS = -Os endif
ifdef CONFIG_OPTIMIZATION_ASSERTIONS_DISABLED CPPFLAGS += -DNDEBUG endif
Enable generation of debugging symbols ​
(we generate even in Release mode, as this has no impact on final binary size.) ​
DEBUG_FLAGS ?= -gdwarf
List of flags to pass to C compiler ​
EXTRA_CFLAGS ?=
ifeq ("$(CONFIG_CHIP_NAME)", "VIRTEX7") E21_CPU_CFLAGS := -march=rv32imc -mabi=ilp32
ASMFLAGS := $(E21_CPU_CFLAGS) CFLAGS := $(strip
        -O2 -Wall -Wchar-subscripts -Wformat -Wuninitialized -Winit-self -Wignored-qualifiers -Wswitch-default -Wunused -Wundef -Werror -Wno-switch-default -Wno-unused -fdata-sections -ffunction-sections -g3
        -fmessage-length=0 -std=gnu99
        -save-temps=obj
CXXFLAGS := $(strip
        -save-temps=obj
        ) else E21_CPU_CFLAGS := -march=rv32imfc
                   -mabi=ilp32f
CFLAGS := (strip −std=gnu99 (OPTIMIZATION_FLAGS) (DEBUGFLAGS) (COMMON_FLAGS)
        (COMMONWARNINGFLAGS)−Wno−old−style−declaration (CFLAGS)
        (E21CPUCFLAGS) (EXTRA_CFLAGS))
        -save-temps=obj
CXXFLAGS := (strip −std=c++11 (OPTIMIZATION_FLAGS) (DEBUGFLAGS) (COMMON_FLAGS)
        (COMMONWARNINGFLAGS) (CXXFLAGS)
        $(E21_CPU_CFLAGS)
        -nostdlib
        -g3
        -fms-extensions
        -ffunction-sections
        -fdata-sections
        -Wall
        -Wchar-subscripts
        -Wformat
        -Winit-self
        -Wswitch-default
        -Wunused
        -Wundef
        -fno-rtti -fno-exceptions
        -save-temps=obj
        -fno-use-cxa-atexit
endif export CFLAGS CPPFLAGS CXXFLAGS ASMFLAGS
Set default values that were not previously defined ​
CC ?= gcc LD ?= ld AR ?= ar OBJCOPY ?= objcopy SIZE ?= size STRIP ?= strip
Set host compiler and binutils ​
HOSTCC := $(CC) HOSTLD := $(LD) HOSTAR := $(AR) HOSTOBJCOPY := $(OBJCOPY) HOSTSIZE := $(SIZE) export HOSTCC HOSTLD HOSTAR HOSTOBJCOPY SIZE
ifndef CONFIG_TOOLPREFIX $(error Please Configure CONFIG_TOOLPREFIX at toolchain.mk) endif
Set target compiler. Defaults to whatever the user has ​
configured as prefix + ye olde gcc commands ​
CC := (calldequote,(CONFIG_TOOLPREFIX))gcc CXX := (calldequote,(CONFIG_TOOLPREFIX))g++ LD := (calldequote,(CONFIG_TOOLPREFIX))ld AR := (calldequote,(CONFIG_TOOLPREFIX))ar OBJCOPY := (calldequote,(CONFIG_TOOLPREFIX))objcopy SIZE := (calldequote,(CONFIG_TOOLPREFIX))size STRIP := (calldequote,(CONFIG_TOOLPREFIX))strip export CC CXX LD AR OBJCOPY SIZE
PYTHON=(calldequote,(CONFIG_PYTHON))
the app is the main executable built by the project ​
APP_ELF:=(BUILDDIRBASE)/(PROJECT_NAME).elf APP_MAP:=(APPELF:.elf=.map)APPBIN:=(APP_ELF:.elf=.bin)
Include any Makefile.projbuild file letting components add ​
configuration at the project level ​
define includeProjBuildMakefile $(if (V),$(info including $(1)/Makefile.projbuild...)) COMPONENT_PATH := $(1) include (1)/Makefile.projbuildendef(foreach componentpath,(COMPONENTPATHS), (if $(wildcard $(componentpath)/Makefile.projbuild),
                $(eval (callincludeProjBuildMakefile,(componentpath)))))
ELF depends on the library archive files for COMPONENT_LIBRARIES ​
the rules to build these are emitted as part of GenerateComponentTarget below ​
also depends on additional dependencies (linker scripts & binary libraries) ​
stored in COMPONENT_LINKER_DEPS, built via bouffalo.mk files' COMPONENT_ADD_LINKER_DEPS variable ​
COMPONENT_LINKER_DEPS ?= $(APP_ELF): (foreachlibcomp,(COMPONENT_LIBRARIES),(BUILDDIRBASE)/(libcomp)/lib$(libcomp).a) $(COMPONENT_LINKER_DEPS) (COMPONENTPROJECTVARS)(summary) LD $(patsubst (PWD)/@) ifeq ((CONFIGZIGBEE),1)(CXX) -o $@ (LDFLAGS)−Wl,−Map=(APP_MAP) else ifeq ((CONFIGCPPENABLE),1)(CXX) -o $@ (LDFLAGS)−Wl,−Map=(APP_MAP) else         $(CC) $(LDFLAGS) -o @−Wl,−Map=(APP_MAP) $(shell find build_out/ -name bugkiller_*.o) endif
all_binaries: $(APP_BIN)
TODO move to bl60x_elftool component ​
$(APP_BIN): $(APP_ELF)         @echo "Generating BIN File to @"ifeq("(CONFIG_CHIP_NAME)", "VIRTEX7")         $(OBJCOPY) -O ihex $< (@:.bin=.hex)elseifeq((CONFIG_ENABLE_ACP),1)         $(OBJCOPY) -S -O binary -R .rom.cpu1 -R .bugkiller_command -R .bugkiller $< (@:.bin=.cpu0.bin)(OBJCOPY) -S -O binary -j .rom.cpu1 $< $(@:.bin=.cpu1.bin)         cp $(@:.bin=.cpu0.bin) (@:.bin=.acp.bin)ddif=(@:.bin=.cpu1.bin) of=$(@:.bin=.acp.bin) bs=512 seek=2 conv=notrunc         cp $(@:.bin=.acp.bin) @elseifeq((CONFIG_LINK_ROM),1)         $(OBJCOPY) -S -O binary -R .romdata -R .rom -R .bugkiller_command -R .bugkiller $< @(OBJCOPY) -S -O binary -j .rom $< (@:.bin=.rom.bin)(OBJCOPY) -S -O binary -j .romdata $< (@:.bin=.romdata.bin)(OBJCOPY) -S -O binary -R .romdata -R .rom -R .bugkiller_command -R .bugkiller $< (@:.bin=.flash.bin)elseifeq((CONFIG_GEN_ROM),1)         $(OBJCOPY) -S -O binary -R .bleromro -R .bleromrw -R .rtosromro -R .rtosromrw -R .bugkiller_command -R .bugkiller $< @(OBJCOPY) -S -O binary -j .bleromro $< (@:.bin=.bleromro.bin)(OBJCOPY) -S -O binary -j .bleromrw $< (@:.bin=.bleromrw.bin)(OBJCOPY) -S -O binary -j .rtosromro $< (@:.bin=.rtosromro.bin)(OBJCOPY) -S -O binary -j .rtosromrw $< (@:.bin=.rtosromrw.bin)(OBJCOPY) -S -O binary -R .bleromro -R .bleromrw -R .rtosromro -R .rtosromrw -R .bugkiller_command -R .bugkiller $< (@:.bin=.flash.bin)else(OBJCOPY) -S -O binary -R .bugkiller_command -R .bugkiller $< $@ endif
$(BUILD_DIR_BASE):         mkdir -p $(BUILD_DIR_BASE)
Macro for the recursive sub-make for each component ​
$(1) - component directory ​
$(2) - component name only ​
Is recursively expanded by the GenerateComponentTargets macro ​
define ComponentMake +$(MAKE) -C (BUILDDIRBASE)/(2) -f (BL60XSDKPATH)/makescriptsriscv/componentwrapper.mkCOMPONENTMAKEFILE=(1)/bouffalo.mk COMPONENT_NAME=$(2) endef
Generate top-level component-specific targets for each component ​
$(1) - path to component dir ​
$(2) - name of component ​
define GenerateComponentTargets .PHONY: component-(2)−buildcomponent−(2)-clean
component-$(2)-build: (callprereqifexplicit,component−(2)-clean) | (BUILDDIRBASE)/(2)         (callComponentMake,(1),$(2)) build
component-$(2)-clean: | (BUILDDIRBASE)/(2) (BUILDDIRBASE)/(2)/component_project_vars.mk         (callComponentMake,(1),$(2)) clean
(BUILDDIRBASE)/(2):         @mkdir -p (BUILDDIRBASE)/(2)
tell make it can build any component's library by invoking the -build target ​
(this target exists for all components even ones which don't build libraries, but it's ​
only invoked for the targets whose libraries appear in COMPONENT_LIBRARIES and hence the ​
APP_ELF dependencies.) ​
(BUILDDIRBASE)/(2)/lib(2).a:component−(2)-build         (details)"Target′^' responsible for '$@'" # echo which build target built this file
add a target to generate the component_project_vars.mk files that ​
are used to inject variables into project make pass (see matching ​
component_project_vars.mk target in component_wrapper.mk). ​
If any component_project_vars.mk file is out of date, the make ​
process will call this target to rebuild it and then restart. ​
(BUILDDIRBASE)/(2)/component_project_vars.mk: $(1)/bouffalo.mk $(COMMON_MAKEFILES) $(SDKCONFIG_MAKEFILE) | (BUILDDIRBASE)/(2)         (callComponentMake,(1),$(2)) component_project_vars.mk endef
define GenerateComponentNameTargets (1)![](/img/bbsdiy/aiwb2/8a4b886c60b5256f.gif)(BUILDDIRBASE)/(1)/lib(1).a(details) "Target '$$^' responsible for '$$@'" endef
(foreachcomponent,(COMPONENT_PATHS),$(eval (callGenerateComponentTargets,(component),$(notdir (component)))))(foreach component,(COMPONENTPATHS),(eval (callGenerateComponentNameTargets,(notdir $(component)))))
app-clean: (addprefixcomponent−,(addsuffix -clean,$(notdir (COMPONENTPATHS))))(summary) RM $(APP_ELF)         rm -f $(APP_ELF) $(APP_BIN) $(APP_MAP)
#flash: all #        cd (BL60X_SDK_PATH)/tools/flash_tool && env SDK_APP_BIN=(APP_BIN) SDK_BOARD=(PROJECTBOARD)SDKNAME=(PROJECT_NAME) SDK_MEDIA_BIN=(APPMEDIABIN)SDKROMFSDIR=(APP_ROMFS_DIR) SDK_DTS=(PROJECTDTS)SDKXTAL=(PROJECT_BOARD_XTAL) BL_FLASH_TOOL_INPUT_PATH_cfg2_bin_input=(APPBIN)./bflbiottool−−chipname=BL602−−baudrate=2000000−−port=/dev/ttyS13−−pt=(PROJECT_PATH)/img_conf/partition_cfg_4M.toml --dts=(PROJECTPATH)/imgconf/blfactoryparamsIoTKitA40M.dts−−firmware=(APP_BIN)
#burn code to bl602 board, now only support BL602 IOT-DVK-3s platform, if you want to support older bl602 board you need change parameter port to /dev/ttyUSB0 flash: all         cd (BL60X_SDK_PATH)/tools/flash_tool && env SDK_APP_BIN=(APP_BIN) SDK_BOARD=(PROJECTBOARD)SDKNAME=(PROJECT_NAME) SDK_MEDIA_BIN=(APPMEDIABIN)SDKROMFSDIR=(APP_ROMFS_DIR) SDK_DTS=(PROJECTDTS)SDKXTAL=(PROJECT_BOARD_XTAL) BL_FLASH_TOOL_INPUT_PATH_cfg2_bin_input=$(APP_BIN) (FLASHTOOLTYPE)−−chipname=BL602−−baudrate=(SERIAL_BAUDRATE) --port=(SERIALPORT)−−pt=(BL60X_SDK_PATH)/tools/flash_tool/chips/bl602/partition/partition_cfg_4M.toml --dts=(BL60XSDKPATH)/tools/flashtool/chips/bl602/devicetree/04−blfactoryparamsIoTKitA40M−20220625.dts−−boot2=(BL60X_SDK_PATH)/tools/flash_tool/chips/bl602/builtin_imgs/boot2_isp_bl602_v6.5.1/boot2_iap_release.bin --firmware=$(APP_BIN) #cd (BL60X_SDK_PATH)/tools/flash_tool && env SDK_APP_BIN=(APP_BIN) SDK_BOARD=(PROJECTBOARD)SDKNAME=(PROJECT_NAME) SDK_MEDIA_BIN=(APPMEDIABIN)SDKROMFSDIR=(APP_ROMFS_DIR) SDK_DTS=(PROJECTDTS)SDKXTAL=(PROJECT_BOARD_XTAL) BL_FLASH_TOOL_INPUT_PATH_cfg2_bin_input=(APPBIN)./bflbiottool−−chipname=BL602−−baudrate=(SERIAL_BAUDRATE) --port=(SERIALPORT)−−pt=(BL60X_SDK_PATH)/tools/flash_tool/chips/bl602/partition/partition_cfg_4M.toml --dts=(BL60XSDKPATH)/tools/flashtool/chips/bl602/devicetree/blfactoryparamsIoTKitA40M.dts−−firmware=(APP_BIN) flash-only:         cd (BL60X_SDK_PATH)/tools/flash_tool && env SDK_APP_BIN=(APP_BIN) SDK_BOARD=(PROJECTBOARD)SDKNAME=(PROJECT_NAME) SDK_MEDIA_BIN=(APPMEDIABIN)SDKROMFSDIR=(APP_ROMFS_DIR) SDK_DTS=(PROJECTDTS)SDKXTAL=(PROJECT_BOARD_XTAL) BL_FLASH_TOOL_INPUT_PATH_cfg2_bin_input=$(APP_BIN) (FLASHTOOLTYPE)−−chipname=BL602−−baudrate=(SERIAL_BAUDRATE) --port=(SERIALPORT)−−pt=(BL60X_SDK_PATH)/tools/flash_tool/chips/bl602/partition/partition_cfg_4M.toml --dts=(BL60XSDKPATH)/tools/flashtool/chips/bl602/devicetree/04−blfactoryparamsIoTKitA40M−20220625.dts−−boot2=(BL60X_SDK_PATH)/tools/flash_tool/chips/bl602/builtin_imgs/boot2_isp_bl602_v6.5.1/boot2_iap_release.bin --firmware=$(APP_BIN) flash-build:         cd (BL60X_SDK_PATH)/tools/flash_tool && env SDK_APP_BIN=(APP_BIN) SDK_BOARD=(PROJECTBOARD)SDKNAME=(PROJECT_NAME) SDK_MEDIA_BIN=(APPMEDIABIN)SDKROMFSDIR=(APP_ROMFS_DIR) SDK_DTS=(PROJECTDTS)SDKXTAL=(PROJECT_BOARD_XTAL) BL_FLASH_TOOL_INPUT_PATH_cfg2_bin_input=$(APP_BIN) (FLASHTOOLTYPE)−−chipname=BL602−−pt=(BL60X_SDK_PATH)/tools/flash_tool/chips/bl602/partition/partition_cfg_4M.toml --dts=(BL60XSDKPATH)/tools/flashtool/chips/bl602/devicetree/04−blfactoryparamsIoTKitA40M−20220625.dts−−boot2=(BL60X_SDK_PATH)/tools/flash_tool/chips/bl602/builtin_imgs/boot2_isp_bl602_v6.5.1/boot2_iap_release.bin --firmware=$(APP_BIN) --build eflash:         cd (BL60X_SDK_PATH)/tools/flash_tool/blflash_tools && env SDK_APP_BIN=(APP_BIN) SDK_BOARD=(PROJECTBOARD)SDKNAME=(PROJECT_NAME) SDK_MEDIA_BIN=(APPMEDIABIN)SDKROMFSDIR=(APP_ROMFS_DIR) SDK_DTS=(PROJECTDTS)SDKXTAL=(PROJECT_BOARD_XTAL) BL_FLASH_TOOL_INPUT_PATH_cfg2_bin_input=$(APP_BIN) (FLASHTOOLTYPE)−−chipname=BL602−−baudrate=(SERIAL_BAUDRATE) --port=(SERIALPORT)−−pt=(BL60X_SDK_PATH)/tools/flash_tool/chips/bl602/partition/partition_cfg_4M.toml --dts=(BL60XSDKPATH)/tools/flashtool/chips/bl602/devicetree/04−blfactoryparamsIoTKitA40M−20220625.dts−−boot2=(BL60X_SDK_PATH)/tools/flash_tool/chips/bl602/builtin_imgs/boot2_isp_bl602_v6.5.1/boot2_iap_release.bin --firmware=$(APP_BIN)
clean: app-clean
erase_flash:         cd (BL60X_SDK_PATH)/tools/flash_tool && env SDK_APP_BIN=(APP_BIN) SDK_BOARD=(PROJECTBOARD)SDKNAME=(PROJECT_NAME) SDK_MEDIA_BIN=(APPMEDIABIN)SDKROMFSDIR=(APP_ROMFS_DIR) SDK_DTS=(PROJECTDTS)SDKXTAL=(PROJECT_BOARD_XTAL) BL_FLASH_TOOL_INPUT_PATH_cfg2_bin_input=$(APP_BIN) (FLASHTOOLTYPE)−−chipname=BL602−−baudrate=(SERIAL_BAUDRATE) --port=(SERIALPORT)−−firmware=(BL60X_SDK_PATH)/tools/flash_tool/chips/bl602/eflash_loader/eflash_loader_40m.bin --erase
PHONY target to list components in the build and their paths ​
list-components:         $(info (calldequote,(SEPARATOR)))         (infoCOMPONENTDIRS(componentssearchedforhere))(foreach cd,(COMPONENTDIRS),(info (cd)))(info (calldequote,(SEPARATOR)))         (infoCOMPONENTS(listofcomponentnames))(info (COMPONENTS))(info (calldequote,(SEPARATOR)))         (infoEXCLUDECOMPONENTS(listofexcludednames))(info $(if (EXCLUDECOMPONENTS),(EXCLUDE_COMPONENTS),(none provided)))         $(info (calldequote,(SEPARATOR)))         (infoCOMPONENTPATHS(pathstoallcomponents)![](/img/bbsdiy/aiwb2/547e559ee01cedfc.gif)(foreach cp,(COMPONENTPATHS),(info $(cp)))
local-ci-test:         ../../tools/ci/scripts/local-ci-test.sh
最终在ota目录生成[color=rgba(0, 0, 0, 0.75)]FW_OTA.bin.xz需要的OTA文件 [color=rgba(0, 0, 0, 0.75)]tools/flash_tool/chips/bl602/ota 目录下生成 6 种 OTA 固件,分别是: [color=rgba(0, 0, 0, 0.75)]FW_OTA.bin:在编译生成的 bin 的头部追加 4K bytes 的 Boot2 Head [color=rgba(0, 0, 0, 0.75)]FW_OTA.bin.hash:在 FW_OTA.bin 尾部追加对其计算的 32 bytes的 Hash 值(sha256) [color=rgba(0, 0, 0, 0.75)]FW_OTA.bin.ota:在 FW_OTA.bin 的头部追加 512 bytes 的 OTA Head [color=rgba(0, 0, 0, 0.75)]FW_OTA.bin.xz:对 FW_OTA.bin 进行 xz 压缩 [color=rgba(0, 0, 0, 0.75)]FW_OTA.bin.xz.hash:在 FW_OTA.bin.xz 尾部追加对其计算的 32 bytes 的 Hash 值(sha256) [color=rgba(0, 0, 0, 0.75)]FW_OTA.bin.xz.ota:在 FW_OTA.bin.xz 头部追加 512 bytes 的 OTA Hea
搭建 HTTP 服务器 OTA 升级时,固件会从 HTTP 服务器下载 OTA 固件进行升级,因此本机需要先搭建好 HTTP 服务器供模组下载固件。
搭建 HTTP 服务器的过程非常简单,只需要安装好 Python 3,然后在 tools/flash_tool/chips/bl602/ota 下执行以下命令即可: python3 -m http.server 9090
第一次需Uart烧写一次,把文件分区、Boot2烧好。 烧录好固件:make flash
查看主机IP地址。
AI-WB2边上路由器,在串口软件一个命令搞定
ota_http_cmd 192.168.88.115 ota host=192.168.88.115 [HTTPC] hdr_len is 204, content_len is 384976 [MTD] >>>>>> Hanlde info Dump >>>>>>       name FW       id 0       offset 0x000e8000(950272)       size 0x00088000(544Kbytes)       xip_addr 0x00000000 [MTD] <<<<<< Hanlde info End <<<<<< otaTotalLength : 384976, bin_size : 557056 [HTTPC] Received 688 Bytes otaoffset : 688 [OTA] [HEADER] ota header is BL60X_OTA_Ver1.0 [OTA] [HEADER] file type is XZ   [OTA] [HEADER] file length (exclude ota header) is 384464 [OTA] [HEADER] ver_hardware is BFL_Module_v1.1 [OTA] [HEADER] ver_software is EVENT_V1.1.1 [OTA] [HEADER] sha256 is C306AFD98DDBBC7C10C849E30791AA323BBF9E4501840BF3535233F73B3A30DC [HTTPC] Received 688 Bytes otaoffset : 864 Write 864[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 1552[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 2240[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 2928[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 3616[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 4304[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 4992[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 5680[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 6368[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 7056[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 7744[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 8432[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 9120[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 9808[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 10496[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 11184[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 11872[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 12560[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 13248[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 13936[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 14624[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 15312[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 16000[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 16688[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 17376[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 18064[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 18752[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 19440[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 20128[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 20816[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 21504[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 22192[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 22880[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 23568[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 24256[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 24944[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 25632[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 26320[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 27008[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 27696[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 28384[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 29072[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 29760[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 30448[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 31136[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 31824[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 32512[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 33200[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 33888[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 34576[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 35264[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 35952[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 36640[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 37328[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 38016[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 38704[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 39392[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 40080[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 40768[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 41456[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 42144[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 42832[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 43520[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 44208[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 44896[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 45584[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 46272[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 46960[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 47648[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 48336[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 49024[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 49712[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 50400[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 51088[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 51776[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 52464[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 53152[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 53840[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 54528[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 55216[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 55904[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 56592[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 57280[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 57968[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 58656[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 59344[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 60032[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 60720[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 61408[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 62096[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 62784[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 63472[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 64160[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 64848[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 65536[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 66224[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 66912[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 67600[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 68288[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 68976[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 69664[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 70352[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 71040[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 71728[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 72416[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 73104[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 73792[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 74480[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 75168[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 75856[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 76544[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 77232[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 77920[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 78608[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 79296[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 79984[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 80672[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 81360[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 82048[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 82736[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 83424[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 84112[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 84800[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 85488[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 86176[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 86864[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 87552[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 88240[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 88928[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 89616[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 90304[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 90992[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 91680[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 92368[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 93056[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 93744[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 94432[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 95120[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 95808[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 96496[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 97184[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 97872[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 98560[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 99248[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 99936[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 100624[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 101312[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 102000[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 102688[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 103376[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 104064[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 104752[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 105440[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 106128[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 106816[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 107504[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 108192[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 108880[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 109568[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 110256[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 110944[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 111632[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 112320[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 113008[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 113696[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 114384[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 115072[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 115760[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 116448[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 117136[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 117824[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 118512[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 119200[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 119888[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 120576[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 121264[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 121952[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 122640[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 123328[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 124016[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 124704[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 125392[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 126080[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 126768[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 127456[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 128144[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 128832[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 129520[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 130208[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 130896[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 131584[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 132272[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 132960[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 133648[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 134336[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 135024[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 135712[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 136400[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 137088[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 137776[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 138464[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 139152[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 139840[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 140528[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 141216[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 141904[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 142592[384976] [HTTPC] Received 1376 Bytes otaoffset : 1376 Write 143968[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 144656[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 145344[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 146032[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 146720[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 147408[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 148096[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 148784[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 149472[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 150160[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 150848[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 151536[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 152224[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 152912[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 153600[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 154288[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 154976[384976] [HTTPC] Received 1376 Bytes otaoffset : 1376 Write 156352[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 157040[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 157728[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 158416[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 159104[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 159792[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 160480[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 161168[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 161856[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 162544[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 163232[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 163920[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 164608[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 165296[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 165984[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 166672[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 167360[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 168048[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 168736[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 169424[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 170112[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 170800[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 171488[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 172176[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 172864[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 173552[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 174240[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 174928[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 175616[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 176304[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 176992[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 177680[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 178368[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 179056[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 179744[384976] [HTTPC] Received 1376 Bytes otaoffset : 1376 Write 181120[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 181808[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 182496[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 183184[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 183872[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 184560[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 185248[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 185936[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 186624[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 187312[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 188000[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 188688[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 189376[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 190064[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 190752[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 191440[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 192128[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 192816[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 193504[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 194192[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 194880[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 195568[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 196256[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 196944[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 197632[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 198320[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 199008[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 199696[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 200384[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 201072[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 201760[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 202448[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 203136[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 203824[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 204512[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 205200[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 205888[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 206576[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 207264[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 207952[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 208640[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 209328[384976] [HTTPC] Received 1376 Bytes otaoffset : 1376 Write 210704[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 211392[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 212080[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 212768[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 213456[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 214144[384976] [HTTPC] Received 1376 Bytes otaoffset : 1376 Write 215520[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 216208[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 216896[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 217584[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 218272[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 218960[384976] [HTTPC] Received 1376 Bytes otaoffset : 1376 Write 220336[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 221024[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 221712[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 222400[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 223088[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 223776[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 224464[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 225152[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 225840[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 226528[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 227216[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 227904[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 228592[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 229280[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 229968[384976] [HTTPC] Received 1376 Bytes otaoffset : 1376 Write 231344[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 232032[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 232720[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 233408[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 234096[384976] [HTTPC] Received 1376 Bytes otaoffset : 1376 Write 235472[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 236160[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 236848[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 237536[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 238224[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 238912[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 239600[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 240288[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 240976[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 241664[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 242352[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 243040[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 243728[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 244416[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 245104[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 245792[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 246480[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 247168[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 247856[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 248544[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 249232[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 249920[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 250608[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 251296[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 251984[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 252672[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 253360[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 254048[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 254736[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 255424[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 256112[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 256800[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 257488[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 258176[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 258864[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 259552[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 260240[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 260928[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 261616[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 262304[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 262992[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 263680[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 264368[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 265056[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 265744[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 266432[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 267120[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 267808[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 268496[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 269184[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 269872[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 270560[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 271248[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 271936[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 272624[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 273312[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 274000[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 274688[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 275376[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 276064[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 276752[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 277440[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 278128[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 278816[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 279504[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 280192[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 280880[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 281568[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 282256[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 282944[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 283632[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 284320[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 285008[384976] [HTTPC] Received 1376 Bytes otaoffset : 1376 Write 286384[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 287072[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 287760[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 288448[384976] [HTTPC] Received 1376 Bytes otaoffset : 1376 Write 289824[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 290512[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 291200[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 291888[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 292576[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 293264[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 293952[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 294640[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 295328[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 296016[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 296704[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 297392[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 298080[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 298768[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 299456[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 300144[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 300832[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 301520[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 302208[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 302896[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 303584[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 304272[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 304960[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 305648[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 306336[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 307024[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 307712[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 308400[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 309088[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 309776[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 310464[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 311152[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 311840[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 312528[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 313216[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 313904[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 314592[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 315280[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 315968[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 316656[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 317344[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 318032[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 318720[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 319408[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 320096[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 320784[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 321472[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 322160[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 322848[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 323536[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 324224[384976] [HTTPC] Received 1376 Bytes otaoffset : 1376 Write 325600[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 326288[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 326976[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 327664[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 328352[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 329040[384976] [HTTPC] Received 1376 Bytes otaoffset : 1376 Write 330416[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 331104[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 331792[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 332480[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 333168[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 333856[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 334544[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 335232[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 335920[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 336608[384976] [HTTPC] Received 1376 Bytes otaoffset : 1376 Write 337984[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 338672[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 339360[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 340048[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 340736[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 341424[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 342112[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 342800[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 343488[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 344176[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 344864[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 345552[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 346240[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 346928[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 347616[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 348304[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 348992[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 349680[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 350368[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 351056[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 351744[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 352432[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 353120[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 353808[384976] [HTTPC] Received 1376 Bytes otaoffset : 1376 Write 355184[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 355872[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 356560[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 357248[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 357936[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 358624[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 359312[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 360000[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 360688[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 361376[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 362064[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 362752[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 363440[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 364128[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 364816[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 365504[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 366192[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 366880[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 367568[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 368256[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 368944[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 369632[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 370320[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 371008[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 371696[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 372384[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 373072[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 373760[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 374448[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 375136[384976] proc_hellow_entry: RISC-V rv32imafc [HTTPC] Received 688 Bytes otaoffset : 688 Write 375824[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 376512[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 377200[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 377888[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 378576[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 379264[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 379952[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 380640[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 381328[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 382016[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 382704[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 383392[384976] [HTTPC] Received 688 Bytes otaoffset : 688 Write 384080[384976] [HTTPC] Received 384 Bytes otaoffset : 384 Write 384464[384976]
Calculated SHA256 Checksum:C306AFD98DDBBC7C10C849E30791AA323BBF9E4501840BF3535233F73B3A30DC Header SET SHA256 Checksum:C306AFD98DDBBC7C10C849E30791AA323BBF9E4501840BF3535233F73B3A30DC [OTA] [TCP] prepare OTA partition info [OTA] [TCP] Update PARTIION, partition len is 384464
上传的附件:
(104.27 KB, 下载次数: 15)
参考 博流官方资料,官司方有点错误 空中升级(OTA
OTA 升级机制可以让设备在固件正常运行时根据接收数据(如通过 Wi-Fi )进行自我更新。
目前 OTA 采用A/B区pingpong设计,OTA文件有两种类型,压缩和非压缩,其中压缩算法采用xz压缩算法,压缩率约为50%-60%。OTA之前需要check一下分区表的 FW 分区的size0和size1是否满足OTA需求。
不是 A/B区pingpong设计。
[pt_table] #partition table is 4K in size address0 = 0xE000 address1 = 0xF000
[[pt_entry]]
type = 0
name = "FW"
device = 0
address0 = 0x10000
size0 = 0x100000
address1 = 0x110000
size1 = 0x100000
compressed image must set len,normal image can left it to 0 ​
len = 0
[[pt_entry]]
type = 0
name = "spiffs"
device = 0
address0 = 0x210000
size0 = 0x28000
address1 = 0x238000
size1 = 0x8000
len = 0
[[pt_entry]]
type = 2
name = "mfg"
device = 0
address0 = 0x240000
size0 = 0x32000
address1 = 0
size1 = 0
len = 0
[[pt_entry]]
type = 3
name = "media"
device = 0
address0 = 0x272000
size0 = 0x1000
address1 = 0
size1 = 0
len = 0
[[pt_entry]]
type = 4
name = "![](/img/bbsdiy/ai_wb2/71f7e0c1f8b22060.gif)SM"
device = 0
address0 = 0x273000
size0 = 0x33000
address1 = 0
size1 = 0
len = 0
[[pt_entry]]
type = 5
name = "KEY"
device = 0
address0 = 0x2A6000
size0 = 0x2000
address1 = 0
size1 = 0
len = 0
[[pt_entry]]
type = 6
name = "DATA"
device = 0
address0 = 0x2A8000
size0 = 0x5000
address1 = 0
size1 = 0
len = 0
[[pt_entry]]
type = 7
name = "factory"
device = 0
address0 = 0x2AD000
size0 = 0x7000
address1 = 0
size1 = 0
len = 0
#if user want to put RF calibration data on flash, uncomment following pt entry #[[pt_entry]] #type = 8 #name = "rf_para" #device = 0 #address0 = 0x1FF000 #size0 = 0x1000 #address1 = 0 #size1 = 0
#len = 0
[[pt_entry]]
type = 0
name = "spiffs"
device = 0
address0 = 0x210000  ##给spiffs文件系统用,开始地址
size0 = 0x28000         ##给spiffs文件系统用,大小
address1 = 0x238000  ##给easyflash文件系统用,开始地址
size1 = 0x8000           ##给easyflash文件系统用,大小
len = 0
[[pt_entry]]
type = 0
name = "FW"
device = 0
address0 = 0x10000
size0 = 0x100000
address1 = 0x110000
size1 = 0x100000
len = 0 是下载到address1 = 0x110000地址容间里,重起后,再解压复制到address0 = 0x10000。
