由 黎明将至! 贡献,Ai-Thinker 进行整理
Ai-WB2-32S MQTT TCP使用 ​
前言 ​
本期博客来介绍一下关于mqtt中tcp的demo的使用。
一、使用步骤 ​
第一步 进入mqtt/tcp目录 ​
cd ~/Ai-Thinker-WB2/applications/protocols/mqtt/tcp
第二步 修改main.c文件内容 ​
gedit ./tcp/main.c
include
<FreeRTOS.h>
include
<task.h>
include
<stdio.h>
include
<string.h>
include
"blog.h"
include
<aos/yloop.h>
include
<aos/kernel.h>
include
<lwip/tcpip.h>
include
<wifi_mgmr_ext.h>
include
<hal_wifi.h>
define
 ROUTER_SSID
"1234567"
//自行修改WiFi名称
define
 ROUTER_PWD
"202013076"
//自行修改WiFi密码
static
wifi_conf_t
 conf =
    .country_code =
"CN"
static
void
wifi_sta_connect
char
* ssid,
char
* password)
wifi_interface_t
 wifi_interface;
    wifi_interface = wifi_mgmr_sta_enable();
    wifi_mgmr_sta_connect(wifi_interface, ssid, password,
NULL
NULL
static
void
event_cb_wifi_event
input_event_t
* event,
void
* private_data)
switch
 (event->code)
case
 CODE_WIFI_ON_INIT_DONE:
            blog_info(
"[APP] [EVT] INIT DONE %lld"
, aos_now_ms());
            wifi_mgmr_start_background(&conf);
break
case
 CODE_WIFI_ON_MGMR_DONE:
            blog_info(
"[APP] [EVT] MGMR DONE %lld"
, aos_now_ms());
            wifi_sta_connect(ROUTER_SSID, ROUTER_PWD);
break
case
 CODE_WIFI_ON_SCAN_DONE:
            blog_info(
"[APP] [EVT] SCAN Done %lld"
, aos_now_ms());
break
case
 CODE_WIFI_ON_DISCONNECT:
            blog_info(
"[APP] [EVT] disconnect %lld"
, aos_now_ms());
break
case
 CODE_WIFI_ON_CONNECTING:
            blog_info(
"[APP] [EVT] Connecting %lld"
, aos_now_ms());
break
case
 CODE_WIFI_CMD_RECONNECT:
            blog_info(
"[APP] [EVT] Reconnect %lld"
, aos_now_ms());
break
case
 CODE_WIFI_ON_CONNECTED:
            blog_info(
"[APP] [EVT] connected %lld"
, aos_now_ms());
break
case
 CODE_WIFI_ON_PRE_GOT_IP:
            blog_info(
, aos_now_ms());
break
case
 CODE_WIFI_ON_GOT_IP:
            blog_info(
"[APP] [EVT] GOT IP %lld"
, aos_now_ms());
            blog_info(
"[SYS] Memory left is %d Bytes"
, xPortGetFreeHeapSize());
extern
void
mqtt_start
void
            mqtt_start();
break
case
 CODE_WIFI_ON_PROV_SSID:
break
case
 CODE_WIFI_ON_PROV_BSSID:
            blog_info(
"[APP] [EVT] [PROV] [BSSID] %lld: %s"
                   aos_now_ms(),
                   event->value ? (
const
char
*)event->value :
"UNKNOWN"
if
 (event->value)
                vPortFree((
void
*)event->value);
break
case
 CODE_WIFI_ON_PROV_PASSWD:
break
case
 CODE_WIFI_ON_PROV_CONNECT:
break
case
 CODE_WIFI_ON_PROV_DISCONNECT:
            blog_info(
"[APP] [EVT] [PROV] [DISCONNECT] %lld"
, aos_now_ms());
break
default
            blog_info(
"[APP] [EVT] Unknown code %u, %lld"
, event->code, aos_now_ms());
/*nothing*/
static
void
proc_main_entry
void
* pvParameters)
    aos_register_event_filter(EV_WIFI, event_cb_wifi_event,
NULL
    hal_wifi_start_firmware_task();
    aos_post_event(EV_WIFI, CODE_WIFI_ON_INIT_DONE,
    vTaskDelete(
NULL
void
main
    blog_set_level_log_component(BLOG_LEVEL_WARN,
"tcp"
"axk_mqtt"
"tcp_transport"
puts
"[OS] Starting TCP/IP Stack..."
    tcpip_init(
NULL
NULL
puts
"[OS] proc_main_entry task..."
    xTaskCreate(proc_main_entry, (
char
"main_entry"
1024
NULL
15
NULL
第三步 修改demo.c文件内容 ​
gedit ./tcp/demo.c
第四步 修改另一个客户端的订阅和发布 ​
二、编译与烧录 ​
第一步 编译 ​
执行make -j8(这里-j8是要参与编译的内核的总数量)
第二步 烧录 ​
将模组连接到电脑上 之后将模组连接到虚拟机上,如下图位置可选择连接
之后执行make flash p=/dev/ttyUSB0 b=115200
跟着提示按下模组的RST键
三、查看运行效果 ​
第一步 断开模组与虚拟机的连接 ​
第二步 打开串口调试助手并连接模组的串口 ​
第三步 重新按下模组的RST键 ​
第四步 查看另一个客户端并发布topic ​
第五步 查看串口调试助手是否接收到客户端发来的消息 ​
原链接:<https://blog.csdn.net/qq_54193285/article/details/136107369?spm=1001.2014.3001.5501>
