▫️ Overview
Ai-M65 Series
The Ai-M65 series modules are dual-band Wi-Fi 6 (2.4/5.8 GHz, both supporting 20 MHz/40 MHz bandwidth and 1024-QAM modulation) & Bluetooth dual-mode modules developed by Ai-Thinker Co.,Ltd., integrating two high-performance RISC-V CPUs and supporting Wi-Fi 802.11a/b/g/n/ac/ax, BT/BLE, and IEEE 802.15.4.
The BL618DG chip is equipped with HP RISC-V processors AP and NP, with clock frequencies of 640 MHz (AP) and 480 MHz (NP), providing rich interfaces including Timer, UART, I2C, SPI, PWM, IPC, SEC_Eng, EMAC, KeyScan, IR, Audio, I2S, Touch, CAM, MJPEG Encoder, MJPEG Decoder, OSD, Display, ADC, SDIO 3.0 (Host & Device), USB 2.0, DMA, and more.
Suitable for audio/video multimedia, IoT, mobile devices, smart home, new energy, and related applications.
▫️ Features
- Supports 2.4 GHz/5 GHz operating frequency bands, MCS0 ~ MCS11
- Wi-Fi 6 (IEEE 802.11a/b/g/n/ac/ax)
- Supports Bluetooth 5.3 dual mode (BT + BLE)
- Wi-Fi and Bluetooth coexist sharing the same antenna; the Bluetooth pin is routed separately inside the chip, and Bluetooth and 2.4 GHz Wi-Fi are switched via an RF switch inside the module, enabling simultaneous Bluetooth and Wi-Fi connections
- Supports IEEE 802.15.4 (Matter/Zigbee/Thread)
- Supports Wi-Fi, BT/BLE, and Zigbee coexistence
- Supports 20 MHz/40 MHz bandwidth, 1T1R
- HP RISC-V processors AP and NP, with clock frequencies of 640 MHz (AP) and 480 MHz (NP), equipped with FPU
- Supports STA, SoftAP, STA + SoftAP, and Sniffer modes
- Supports LDPC, STBC, Beamforming, DL/UL OFDMA, MU-MIMO, TWT (Target Wake Time), SR (Spatial Reuse), ER (Extended Range)
- 4/8/16 MB Flash, 4/8 MB PSRAM, 852 KB SRAM (320 KB OCRAM, 320 KB WRAM, 128 KB MRAM, 16 KB XRAM, 64 KB BT/BLE RAM, 4 KB HBN RAM), 512-byte eFuse
- Rich peripheral interfaces: Timer, UART, I2C, SPI, PWM, IPC, SEC_Eng, EMAC, IR, Audio, I2S, Touch, CAM, MJPEG Encoder, MJPEG Decoder, OSD, Display, ADC, SDIO 3.0 (Host & Device), USB 2.0, DMA, etc.
- Supports PDS power-down sleep and HBN sleep mode, sleep current in the μA range
- Integrated RF Balun, PA/LNA
- Supports secure boot, firmware encryption & signing, secure debugging, TrustZone, and full hardware cryptography: AES/MD5/SHA/PKA/TRNG
- Supports AES-ECB/CBC/CTR/GMAC/XTS modes
- Universal AT commands for quick deployment
- Supports secondary development, integrated with Windows and Linux development environments
▫️ Selection Table
| Product Image |
| Wireless Protocol |
| Chip |
| Module Flash Size |
| Frequency Band (MHz) |
| Package |
| Dimensions (L×W×H) (mm) |
| Operating Temp Range (℃) |
| Storage Temp Range (℃) |
| Antenna Type |
| Available GPIO Count |
| Min Supply Voltage (V) |
| Max Supply Voltage (V) |
| RX Current (mA) |
| Deep Sleep Current (μA) |
| Certifications |
| Modulation |
2. Datasheets, PCB Footprint, Schematics
| Module | Datasheet | PCB Footprint | Schematic Diagram | Chip Datasheet |
| Ai-M65S-01 | - | - | - | - | - |
| Ai-M65P-32S | View | - | - | - | - |
| Ai-M65P-32S | - | - | - | - | - |
| Ai-M65L-32S | - | - | - | - | - |
| Ai-M65S-01-Kit | - | - | - | - | - |
| Ai-M65P-32S-Kit | - | - | - | - | - |
| Ai-M65L-32S-Kit | - | - | - | - | - |
- ASCII (.asc) file import into Altium Designer (AD) instructions: Click to Download
3. Firmware Related
▫️ Firmware Download and Debugging
| Module Model | Firmware ID | Firmware Description | Version | Download Link |
| Ai-M65P-32S | ⭐xxxx | AT Middleware Standard Firmware | - | Uploading |
| Ai-M65L-12F | ⭐xxxx | AT Middleware Standard Firmware | - | Uploading |
Combo-ATFirmware Changelog: Click to View- Firmware Download Tool: Uploading
- Firmware Flashing Guide: Uploading
4. Development Guide
▫️ Secondary Development Guide
Secondary Development SDK Source Code: Click to View
Secondary Development SDK Setup Tutorial: Click to View
5. FAQ
- Common Questions FAQ: Uploading...
6. Test Reports
| Module Model | Test Report |
| Ai-M65S-01 | Uploading |
| Ai-M65P-32S | Uploading |
| Ai-M65L-32S | Uploading |
7. Certification Related
▫️ Certification
- Series Certification: Click to View
