▫️ Key Features ​
Ra-01
  • The Ra-01 LoRa module utilizes the SX1278 RF chip featuring SEMTECH's LoRa™ modulation.
  • This technology enables ultra-long-range spread spectrum communication with high sensitivity (-148dBm), +20dBm transmit power, enhanced interference immunity, and minimized current consumption.
  • Compared to traditional modulation, LoRa™ significantly improves blocking resistance and selectivity, resolving the inherent trade-off between range, interference immunity, and power consumption. Typical applications include automated meter reading, building/home automation, security systems, and remote irrigation.
▫️ Technical Highlights ​
  • LoRa™ modem
  • Supports FSK, GFSK, MSK, GMSK, LoRa™, and OOK modulation methods
  • Supports frequency bands of 410MHz~525MHz
  • Operating voltage: 3.3V, maximum output: +20dBm, maximum operating current: 105mA
  • Low power consumption in receiving state: receiving current is 12.15mA, standby current is 1.6mA
  • High sensitivity: as low as -140dBm
  • Small-size dual-row stamp hole surface-mount package
  • The module adopts an SPI interface, uses half-duplex communication, with CRC and a data packet engine of up to 256 bytes
Default comparison: modules matching "Ra-01"
ModuleDatasheetsPCB FootprintsChip Manual
Ra-01ViewDownloadSX1276 Manual (EN)
ModuleCertificateLink
Ra-01CE (RED)View
Ra-01FCCView
To learn more
