▫️ Key Features ​
Ra-09(H)
  • The Ra-09(H) module is a LoRaWAN module jointly developed by Ai-Thinker Co., Ltd. and ST. The module uses the STM32WLE5CCU6 chip, with 256 KB Flash, 64 KB SRAM, and a 32-bit Arm® Cortex®-M4 48MHz core. The Ra-09(H) module comes pre-installed with AT firmware, allowing direct use to connect to LoRaWAN gateways.
Ra-09-DTU
  • The Ra-09-DTU is an intelligent wireless data communication DTU developed by Shenzhen Ai-Thinker Co., Ltd. using the company's own Ra-09 LoRa module. It utilizes LoRa wireless technology for ultra-long-distance spread spectrum communication.
▫️ Technical Highlights ​
  • Excellent anti-interference capability, capable of normal operation in complex interference environments
  • Minimum receiving sensitivity: -140dBm (SF=12/BW=125KHz)
  • Maximum transmit power: +22dBm
  • Operating frequency: (Ra-07/08/09/09-DTU) 410MHz~525MHz (default), (Ra-07H/08H/09H) 803MHz~930MHz (default)
  • Power supply voltage: 3.3V (Ra-07/08/09/09/07H/08H/09H), 12V (Ra-09-DTU)
  • Transmit operating current: 119mA (full load power consumption)
  • Receive operating current: 5.15mA
Default comparison: modules matching "Ra-09"
Ra-09ViewDownload
Ra-09HViewDownload
Ra-09-DTUViewN/A
3. Firmware Management ​
ModuleFirmware BuildFirmware DescriptionVersionDownload LinkAT Command Reference
Ra-09⭐2298号AT Standard Firmware (CN470)V1.1.0DownloadAT Command Set
Ra-09H⭐3412号AT Standard Firmware (EU868)V1.1.0DownloadAT Command Set
Ra-09H⭐2454号AT Standard Firmware (US915)V1.1.0DownloadAT Command Set
Ra-09H⭐2455号AT Standard Firmware (IN865)V11.1.0DownloadAT Command Set
Ra-09H⭐3411号AT Standard Firmware (AU915)V1.1.0DownloadAT Command Set
Ra-09H⭐3397号AT Standard Firmware (KR920)V1.1.0DownloadAT Command Set
Ra-09H⭐3410号AT Standard Firmware (AS923-1)V1.1.0DownloadAT Command Set
Ra-09H⭐3396号AT Standard Firmware (AS923-2)V1.1.0DownloadAT Command Set
Ra-09-DTU2343号DTU Standard FirmwareV1.2.0DownloadAT Command Set
Ra-09/Ra-09H-Passthrough FirmwareV1.0.0Downloaduser manul
4. Compliance & Testing ​
ModuleReport
Ra-09View
Ra-09HView
ModuleReport
Ra-09-DTUView
Ra-09View
ModuleCertificateLink
Ra-09HCE (RED)View
Ra-09HFCCView
Ra-09CE (RED)View
Ra-09FCCView
