▫️ Key Features ​
Ra-05
  • Ra-05 is a 2.4GHz RF transceiver module developed by Shenzhen Ai-Thinker Co., Ltd. Equipped with Semtech's SX1281 RF chip as the core processor, this module supports multiple modulation methods such as LoRa, FLRC, and GFSK, and is compatible with Bluetooth protocols. It is a pure RF transceiver module that requires an MCU for driving or a dedicated SPI debugging tool.
  • LoRa's direct-sequence spread spectrum technology enables longer communication distances, with advantages of a wider power spectrum and strong anti-interference capabilities. The module features a hardware FEC (Forward Error Correction) algorithm, which offers high coding efficiency and robust error correction. In the event of burst interference, it can actively correct corrupted data packets, significantly enhancing reliability and transmission range.
  • The module offers high transmit power and receive sensitivity, with excellent performance in spectral characteristics, harmonic spurs, and channel crosstalk. Additionally, it features a compact size and strong package compatibility.
▫️ Technical Highlights ​
  • Supports the license-free ISM 2.4GHz band.
  • Supports data rates from 1 kbps to 2 Mbps.
  • Maximum transmit power of 12.5 dBm, adjustable in multiple software-controlled steps.
  • Receive sensitivity (per chip datasheet) up to -132 dBm in LoRa mode.
  • Operates from 1.8 to 3.6 VDC; optimal performance is ensured with a supply voltage above 3.3 V.
  • Designed to industrial standards, supporting long-term operation from -40°C to 85°C.
  • Supports multiple modulation modes (GFSK Mode, FLRC Mode, LoRa Mode).
  • Exceptional anti-blocking characteristics.
  • Features an onboard antenna while being compatible with IPEX connectors.
Default comparison: modules matching "Ra-05"
Ra-05ViewDownload
ModuleCertificateLink
Ra-05CE (RED)View
Ra-05FCCView
To learn more
4. Compliance & Testing ​
  • Ra-05 Power Consumption Test Report:View
  • Ra-05 Hardware Reliability Test Report:View
