▫️ Key Features ​
Ra-01S-p
  • The Ra-01S-P is a LoRa series module designed and developed by Shenzhen Ai-Thinker Co., Ltd. Built for ultra-long-range spread spectrum communication, it employs the SX126x RF chip with a LoRa™ remote modem, delivering robust anti-interference capabilities and minimal power consumption.
▫️ Technical Highlights ​
  • Supports FSK, GFSK, and LoRa® modulation.
  • Covers the frequency band 410MHz–525MHz.
  • Maximum transmit power of +29dBm at 700mA operating current.
  • Ultra-high sensitivity: As low as -137dBm@SF10125KHz.
  • Compact size: 17×16×3.2(±0.2)mm, dual-row stamp-hole SMD package.
  • Supports spreading factors SF5/SF6/SF7/SF8/SF9/SF10/SF11/SF12.
  • Low power consumption in receive mode: Minimum 11mA receive current.
  • SPI interface with half-duplex communication, CRC, and 256-byte packet engine.
  • Flexible antenna installation: Compatible with half-hole pads, through-hole pads, and IPEX connectors.
Default comparison: modules matching "Ra-01S"
ModuleDatasheets
Ra-01S-PView
3. STM32F103C8T6 HAL-based driver ​
ModuleLink
Ra-01S-PDownload
ModuleCertificateLink
Ra-01S-PCE (RED)View
Ra-01S-PFCCView
To learn more
5. Compliance & Testing ​
  • Ra-01S-P Power Consumption Test Report:View
  • Ra-01S-P Hardware Reliability Test Report:View
